Hyperlinks off text and shapes?
Post your questions, bug reports and suggestions here for Presentations Mobile for Android.
daynaga
Post by daynaga » Wed Mar 20, 2013 7:03 am
Hello,
I was wondering, does the software support hyperlinks (on Android) to other slides within the same deck as well as creating links off of shapes? I'd like to use this software to prototype UI interaction and this feature is critical to me.
Cheers,
Derrick
Re: Hyperlinks off text and shapes?
Post by sven-l » Thu Mar 21, 2013 11:11 am
Hyperlinks do not work in the current version but the developers seemed to have solve the problem and it should work properly in one of the next updates.
daynaga
Post by daynaga » Fri Mar 22, 2013 12:45 am
Thanks so much. Any idea when the next update will be rolled out? Thanks in advance.
Post by sven-l » Fri Mar 22, 2013 11:53 am
There is no release date available yet. We will inform you via our newsletter as soon as the update is out.
Return to “Presentations Mobile for Android”
