tables in slide
Post your questions, bug reports and suggestions here for Presentations Mobile for Android.
ncc1701d
tables in slide
Post by ncc1701d » Sun Mar 10, 2013 4:41 am
I can't seem to be able to edit interview cells within a table in a slide.
Re: tables in slide
Post by sven-l » Mon Mar 11, 2013 4:36 pm
Could you please send us a sample file to forum(at)softmaker.de referring to that thread? Then I could have a look at this issue. Thank you!
ncc1701d
Re: tables in slide
Post by ncc1701d » Wed Mar 13, 2013 3:32 am
Well now I can edit the cells but bar graph slide don't show up at all ( it did on Kingsoft program). Plus it is soooooooooooo slow to load, even just changing slides or getting into edit mode. Hope this can be fixed or else i will need to look at the other softwares out there
Re: tables in slide
Post by sven-l » Mon Mar 18, 2013 11:20 am
Which device are you using? Is it slow with all files?
ncc1701d
Re: tables in slide
Post by ncc1701d » Wed Mar 20, 2013 2:44 am
Using infinity by Asus tf700 on jellybean 4.1.1. OK with editing document on textmaker, but snail pace with presentations. 10 days left of trial version and would buy if not this slow!
Re: tables in slide
Post by sven-l » Thu Mar 21, 2013 10:58 am
Please send us that file to forum(at)softmaker.de if possible. Thank you!
ncc1701d
Re: tables in slide
Post by ncc1701d » Thu Apr 04, 2013 3:22 am
I did send a file in a few days ago.
Return to “Presentations Mobile for Android”
