PM file deleting
Post your questions, bug reports and suggestions here for PlanMaker Mobile for Android.
Heikneuter
PM file deleting
Post by Heikneuter » Mon Sep 01, 2014 6:56 pm
How can i delete a file in PM on android-tablet?
Re: PM file deleting
Post by martin-k » Mon Sep 01, 2014 7:29 pm
In the file dialog, long-tap on the file name and choose Delete.
Heikneuter
Post by Heikneuter » Wed Sep 17, 2014 2:44 pm
Dear Martin,
When i long-tap the file it opeens the file' no option 'delete' appears....i am a new tablet user but work on PC (Windows and mac) so i don't understand why PM does nog give this possibility.
Regards
Post by martin-k » Wed Sep 17, 2014 3:44 pm
Go to Tools/About and let me know the version number of your PlanMaker Mobile.
Heikneuter
Post by Heikneuter » Wed Sep 17, 2014 4:28 pm
Dear Martin,
my PM version is 1.0 and it was installed automatically on the Medion Lifetab E10320 bought at ALDI.
When i open the PM app the only possibility i have to select a file is via the file toolbar - open files, so if i long-tap there on a file it opens the file. i cannot find another file list
where i could long-tap and then choose the option 'delete'.
Grtz
Post by martin-k » Wed Sep 17, 2014 7:52 pm
1.0 is not the revision ID that I was looking for. There is a more detailed version info in Menu > Tools > About.
But since you told me that you have a Medion tablet, I know that your revision is a bit older than the current builds. It is Medion's task to distribute updated builds (they already have it, and I _thought_ they were already pushing it to customers via online update). Can you contact their tech support and ask for the updated revision?
Return to “PlanMaker Mobile for Android”
