Cannot open dbf (dbase) files
Post your questions, bug reports and suggestions here for PlanMaker Mobile for Android.
TJBaker
Post by TJBaker » Fri Jan 10, 2014 8:29 pm
Any attempt to open a dbf file results in "unknown file format" error.
Planmaker mobile rev 685.1217
Why does this not work?
Suggestions?
Re: Cannot open dbf (dbase) files
Post by sven-l » Mon Jan 13, 2014 11:12 am
There is not much we can say without the file. Please send it to forum(at)softmaker.de referring to that thread if possible. Thank you!
TJBaker
Post by TJBaker » Sat Jan 18, 2014 3:07 am
I will try to attach a sample db file here in addition to sending the file via email. Thanks,
TJBaker
Post by TJBaker » Sat Jan 18, 2014 3:13 am
I'll rename the .dbf adding .txt to see if that will allow me to upload here.
JOBMASTR.DBF.txt
Added .txt to filename, delete the ".txt" Fails to open in Planmaker android. Error = unknown format or similar statement.
(269.04 KiB) Downloaded 200 times
Post by sven-l » Mon Jan 20, 2014 1:32 pm
That problem is reporducible for me (the same file opens properly in PlanMaker 2012 for Windows). I referred that problem to the developers and will inform you here as soon as I have more information.
Post by sven-l » Tue Feb 25, 2014 2:06 pm
That problem should no longer occur in the next version of PlanMaker for Android.
Return to “PlanMaker Mobile for Android”
