Suggestion: Remember previously selected file type filter
Post your questions, bug reports and suggestions here for PlanMaker Mobile for Android.
pelago
Post by pelago » Mon Dec 02, 2013 2:55 pm
In the File Open screen, you can choose which file types to show using the drop-down list at the bottom, e.g. to just show Excel files. However, next time you enter the File Open screen, the filter has reverted to showing all supported document types. Can you change the software so that the file type filter choice made by the user would persist, in a similar way to how it currently remembers the last folder used?
Re: Suggestion: Remember previously selected file type filte
Post by sven-l » Fri Dec 13, 2013 10:33 am
This is not possible yet but I will forward your suggestion to the developers.
Return to “PlanMaker Mobile for Android”
