File Format Preference
Post your questions, bug reports and suggestions here for PlanMaker Mobile for Android.
Byron Siegel
Post by Byron Siegel » Sun Nov 03, 2013 1:17 pm
Aside from using templates (*.pmv), are there other advantages to using the PlanMaker file format (*.pmd) over the Excel 2007/2010 format (*.xlsx)?
TIA, Byron
Re: File Format Preference
Post by sven-l » Mon Nov 04, 2013 2:24 pm
PlanMaker "knows" a few functions that do not work in MS Excel (they are all listed in the manual: http://www.softmaker.com/english/manuals_en.htm). If you save your file in MS Excel file format (.xls or .xlsx) these functions get lost (they are replaced by their results). Apart from that there are not many disadvantages if you use .xls or .xlsx instead of .pmd or .pmv as file format.
Return to “PlanMaker Mobile for Android”
