page format - margin
Post your questions, bug reports and suggestions here for PlanMaker Mobile for Android.
denisemega
Post by denisemega » Mon May 13, 2013 7:57 pm
Hello,
I would like to know if it is possible to set the margins in PlanMaker.
I use a 1 page file from excel but when I open it in Plan Maker it becomes 2 pages...
Thank you in advance
Re: page format - margin
Post by sven-l » Tue May 14, 2013 9:11 am
You can set margins and the paper size in File=>Page Setup.
denisemega
Post by denisemega » Wed May 15, 2013 1:02 am
Dear Sven,
I was not able to find margin at page setup.
The only option I have here is for page size.
Please see the print of the options I get (it is in portuguese, but I think you can have a idea)...
Thanks again
Edit 1: Not possible to submit the screenshot... Not supported.
Post by sven-l » Thu May 16, 2013 8:47 am
I see that this is not possible yet in the Android version (only in the Windows version). Margin settings are on the agenda for future updates.
emidon518
Post by emidon518 » Thu May 16, 2013 12:32 pm
The style files and templates provided here have been created to ensure that the margin requirements are adequately met. Note that each conference has its own page setting requirements.........
emidon518
Return to “PlanMaker Mobile for Android”
