new line inside the same cell
Post your questions, bug reports and suggestions here for PlanMaker Mobile for Android.
denisemega
Post by denisemega » Thu Apr 25, 2013 5:16 pm
Hi guys,
So far this software provided me with the best compatibility with my excel report.
I would like to know if it is possible to create a second line inside the same cell (something equivalent to alt+enter in excel).
Right now I am writing in another office software and copying it to PlanMaker every time I need more than 1 paragraph at the same cell, but you can imagine this sucks.
Thanks in advance
Re: new line inside the same cell
Post by sven-l » Fri Apr 26, 2013 8:59 am
This is not yet possible (not even with Hacker's keyboard, which comes with a CTRL key). I will refer this as a feature request to our developers.
Znatok
Post by Znatok » Tue Aug 14, 2018 10:42 pm
there is a workaround
If you copy an unprintable character (circled in an oval) and paste it into PlanMaker, you get:
(There must be an ALT code. I did not find it.
Other ALT-codes in PlanMaker cells work.)
Return to “PlanMaker Mobile for Android”
