Printing from PlanMaker for Android
Post your questions, bug reports and suggestions here for PlanMaker Mobile for Android.
larryreb
Post by larryreb » Mon Apr 01, 2013 2:55 pm
I have not been able to find this feature. I usually use cloudprint to ptint from my android Device and it is important that I can print easily from
PlanMaker as well. Perhaps there is a function already for this. If not, it is essential to include it in the next version.
Re: Printing from PlanMaker for Android
Post by sven-l » Wed Apr 03, 2013 9:20 am
You need a third party tool like printershare in order to print from PlanMaker. In PlanMaker invoke Menu=>File=>Send=>PDF and select printershare as destination for the send command. Printershare should detect your printer and print the file.
larryreb
Post by larryreb » Wed Apr 03, 2013 11:42 pm
Thank you. The above worked very well and I was able to print using CloudPrint.
Return to “PlanMaker Mobile for Android”
