Adjust zoom enhancements
Post your questions, bug reports and suggestions here for PlanMaker Mobile for Android.
pelago
Post by pelago » Sun Mar 24, 2013 10:09 pm
When you adjust the zoom using two fingers, it would be good if there was a momentary popup somewhere showing you the zoom level that you are currently at.
Also, if you adjust the zoom using this method, then use the menu and go into zoom, custom, it would be good if the textbox showed you the current zoom level, rather than being blank as it is currently.
Re: Adjust zoom enhancements
Post by sven-l » Tue Mar 26, 2013 11:14 am
Thank you for your suggestions. I referred them to our developers.
pelago
Post by pelago » Wed Mar 27, 2013 10:35 am
Thanks!
Return to “PlanMaker Mobile for Android”
