Re-ordering sheets
Post your questions, bug reports and suggestions here for PlanMaker Mobile for Android.
pelago
Re-ordering sheets
Post by pelago » Sun Mar 24, 2013 2:50 pm
Currently it is possible to insert, delete and rename sheets. I would find it useful to change their order as well.
Re: Re-ordering sheets
Post by sven-l » Tue Mar 26, 2013 10:14 am
You cannot rename sheets yet but you can create new sheets and delete old ones. Just click on the icon with the four sheets on the toolbar to see the options.
pelago
Post by pelago » Tue Mar 26, 2013 10:21 am
I certainly can rename sheets in PlanMaker for Android! But that's not what I was asking for - I was asking if you could add a new feature to allow us to re-order sheets.
Post by sven-l » Wed Mar 27, 2013 9:09 am
That's on the agenda for future versions.
pelago
Post by pelago » Wed Mar 27, 2013 10:31 am
Thanks!
pelago
Post by pelago » Mon Dec 02, 2013 2:40 pm
I see we still can't re-order worksheets in build 684, which is disappointing. While you're considering this functionality, you might also consider adding long-press functionality on the new worksheet selection toolbar. E.g. long-pressing on a sheet could bring up a context menu to choose to delete, rename, or move (I.e. re-order) the sheet. You could have Insert Before and Insert After in the menu, too.
Return to “PlanMaker Mobile for Android”
