Hello,
I live in Sweden and is in a process of moving some word processor files from my MAC to an Android phone (Samsung Galaxy S3). I bought and downloaded Textmaker from GooglePlay and so far I'm happy with the program. I have registered the program with you.
I have my files saved in Open Office to .rtf and they display correctly in Open Office. I copied them into your folder Softmaker on Android. When I look at the files in File/Open they display correctly with Swedish characters (å,ä,ö). However, when I open a file the Swedish characters are replaced with a question mark in the body of the text. Is this a problem with the character set? How can I remedy this? You must have the same situation in Germany with ü among others. How do you solve this?
OS X 10.8.5
Open Office 4.0.1
Android 4.3
Samsung Galaxy S3
Textmaker for Android rev 686.0131
Thanks for your help
Gunnar
Scandinavian Characters in Textmaker Android
Re: Scandinavian Characters in Textmaker Android
It sounds like a font problem. Please make sure that the used font is installed on the Android device (see http://www.softmaker.com/english/tipsandroid_en.htm) or use a font with Swedish characters.
