Google Drive not accessable
Post your questions, bug reports and suggestions here for TextMaker Mobile for Android.
hkeiner
Post by hkeiner » Sat Mar 08, 2014 7:28 pm
Using the trial version of TextMaker. When attempting to log in to Google Drive via the OPEN screen I get a dialogue screen that says "web page not available" along with text shown below. Drop box works OK though. Any suggestions?
The webpage at http://localhost/?code=4/0VLqtR1QDKcw9e ... 0F8rORFiQI might be temporarily down or it may have moved permanently to a new web address.
Suggestions:
Make sure you have a data connection
Reload this webpage later
Check the address you entered
Re: Google Drive not accessable
Post by sven-l » Mon Mar 10, 2014 2:18 pm
Is your internet connection (WLAN) activated?
jimisen
Post by jimisen » Tue Sep 16, 2014 8:27 pm
If I try to select a previously edited document on my Google Drive from the list of recent docs, rather than using the Open dialog, I get an error message complaining about the header and showing a block of code. Once I use the Open dialog to access Google Drive, this problem goes away. An elegant solution would recognize the need to go to the Google connect, but I consider the error a feature or request for enhancement rather than a bug. Seen under the September beta 713.0909.fl.
jimisen
CyanogenMod Ovation, Android 4.2.2, kernel 3.0.31-green+ on a Nook HD+, 32GB
Post by sven-l » Thu Dec 18, 2014 8:24 am
I can reproduce that issue and informed the developers. I will report here as soon as we have a solution.
Post by sven-l » Fri Dec 19, 2014 2:56 pm
That problem has been fixed and should no longer occur with the next service pack.
Return to “TextMaker Mobile for Android”
