Upgrade not downloading
Post your questions, bug reports and suggestions here for TextMaker Mobile for Android.
cwatkins
Post by cwatkins » Fri Dec 20, 2013 5:05 pm
Recently I noticed that there was an upgrade available for the Android version ofTextmaker Office.
I clicked on the 'apk' link in th 'Check for updates' section of Textmaker, but all tht happened was the screen flicked a bit - but nothing was downloaded!
I've tried going direct to the web site, but all it says is to use the 'Check for update' section in the application!
I've tried it many times, even after restarting my TF700t, but the upgrade doesn't download.
Am I doing something wrong, or is there a problem with the upgrade?
:oops:
Re: Upgrade not downloading
Post by sven-l » Thu Jan 02, 2014 2:34 pm
If you have purchased the Office directly in our shop you can use the direct download links in the e-mail with the unlock code we sent you after the purchase. After a new installation a newest version should be installed on your device.
Return to “TextMaker Mobile for Android”
