Nexus 7 + TextMaker + Microsoft Wedge keyboard
Post your questions, bug reports and suggestions here for TextMaker Mobile for Android.
falkor
Post by falkor » Wed Sep 11, 2013 10:09 pm
Hi, I can't understand why the first key I press on the Microsoft Wedge keyboard makes TextMaker to quit. Then, if I relaunch TextMaker everything works perfectly.
Re: Nexus 7 + TextMaker + Microsoft Wedge keyboard
Post by sven-l » Thu Sep 12, 2013 9:51 am
Does that happen with every key on the Microsoft Wedge keyboard?
falkor
Post by falkor » Thu Sep 12, 2013 11:29 am
sven-l wrote:Does that happen with every key on the Microsoft Wedge keyboard?
Yes, exactly, but there's must be something wrong also outside TextMaker becouse whichever key I press, with no apps running but the stock launcher, the Google search app window appears . I don't know if this is normal.
Thank you
Post by sven-l » Fri Sep 13, 2013 9:02 am
Ok, thank you! I informed the developers. Which Android version are you using? Are you working with TextMaker rev.678 (Help=>About)?
falkor
Post by falkor » Fri Sep 13, 2013 5:00 pm
sven-l wrote:Ok, thank you! I informed the developers. Which Android version are you using? Are you working with TextMaker rev.678 (Help=>About)?
Android 4.3 and TextMaker rev 678.3225. I've found "About" under the "Tools" menu. The "Help" icon launches the TM manual and, by the way, trying to search for the word "Help" within the manual makes TextMaker to quit.
Android Device System Information as written by Text Maker:
https://drive.google.com/?tab=wo&authuser=0#my-drive
Bye.
Post by sven-l » Mon Sep 16, 2013 9:04 am
Thank you! I will have a look at it.
seasidepb
Post by seasidepb » Sat Jun 21, 2014 9:19 pm
I have the same setup (first generation Nexus 7 + Microsoft Wedge keyboard) and I've not had that problem - if that's any help. I'm using Android 4.4.3.
Return to “TextMaker Mobile for Android”
