can't input left and right quotes
Post your questions, bug reports and suggestions here for TextMaker Mobile for Android.
erehwon
Post by erehwon » Wed Jan 09, 2013 12:44 am
other versions of textmaker allow left and right quotes on the soft keyboard. (eg windows phone)
How do we do that with textmaker android?
thanks
David
Re: can't input left and right quotes
Post by sven-l » Wed Jan 09, 2013 10:21 am
Smart quotes are not possible because they confuse the input editors (IME, word completion etc.) of Android.
Post by Jossi » Wed Jan 09, 2013 5:46 pm
In the German forum, a user recommended MultiLing Keyboard (free app in Google Play Store) for typing left and right quotes.
erehwon
Post by erehwon » Thu Jan 10, 2013 3:17 am
Do they say how they do it with MultiLing? Do they provide the actual keys, or do you have to press a combination of keys?
I'm currently using the hackers keyboard, I can swap to French or Croation alphabet (and a lot more), but none of them have the left and right quotes. I'll give multiling a try.
thanks
David
erehwon
Post by erehwon » Thu Jan 10, 2013 5:07 am
This is a follow up to my earlier post.
I've discovered I can enter left or right quotes using hacker's Keyboard.
It has a compose mode (long press the circle key) which allows you to enter key combination that will generate the desired characters:
<" generates left quote
>" generates right quote
<' generates left single quote
>' generates right single quote
Their website gives a java file that contains all the key combinations:
http://code.google.com/p/hackerskeyboar ... uence.java
regards
David
Jake
Post by Jake » Thu Jan 10, 2013 11:17 am
For hardware keyboards, if your phone is rooted, you can dig into the kcm file and re-program alt-keystroke to fit your needs. For instance, on my Sidekick 4G, alt-f now brings up a left double quote instead of a bracket (alt-shift-f still brings up a bracket).
I have all manuscript punctuation necessary, but it was tricky. Curly quotes won't even show up in some word processors (ie KingSoft).
This is not a solution for everybody, and if users want to put together a proper manuscript, I hope TM can find a non-rooted workaround.
Jake
Return to “TextMaker Mobile for Android”
