'Not enough memory'
Post your questions, bug reports and suggestions here for TextMaker Mobile for Android.
Mark Davies
'Not enough memory'
Post by Mark Davies » Tue Sep 04, 2012 8:41 am
I'm trying to cut and paste some text from TM and I'm being given the message, 'Not enough memory'. It's only a few lines, so this doesn't seem reasonable. I've restarted the app and even cleared its data (not so smart), but I still get the same message.
Just before I sent this I tried once more, this time not restoring from the cache. Whether it was this or that I started the highlighting from the other end, either way I finally got to cut the text successfully. Any idea if this is a regular problem?
I'm using an Asus tf201, so I'd have thought it's not a memory issue of the machine (and I killed all apps in case and it made no difference).
Picture of the offending text
Mark Davies
Re: 'Not enough memory'
Post by sven-l » Wed Sep 05, 2012 9:40 am
Does it help to restart the machine? Which Android version is installed?
Mark Davies
Post by Mark Davies » Wed Sep 05, 2012 1:24 pm
Android version is 4.0.3. As I said, it eventually worked when I didn't restore from the cache. I've not encountered the problem since.
Mark Davies
Tripple26
Post by Tripple26 » Fri Apr 17, 2015 12:47 pm
Textmaker cannot read equations placed into MS Word documents. They are just blanks. I am wondering how it can be used when this essential feature is missing. I have tried it with several docs.
DevIL jiN
Post by sven-l » Fri Apr 17, 2015 2:53 pm
Tripple26 wrote:Textmaker cannot read equations placed into MS Word documents. They are just blanks. I am wondering how it can be used when this essential feature is missing. I have tried it with several docs.
This feature is not yet available (reading formulas created with the MS Word equation editor). This is on the agenda for the future.
Return to “TextMaker Mobile for Android”
