Zoom size
pdagadget65
Zoom size
Post by pdagadget65 » Tue Jan 31, 2017 10:58 am
Is there a way to setup Textmaker so that it always opens documents at %50 zoom?
Re: Zoom size
Post by sven-l » Wed Feb 01, 2017 4:37 pm
The zoom size is always stored in the document. so if you set the zoom to e.g. 200% and save the document, it will be opened with that zoom size the next time you load it. You can change the zoom of the standard template (Normal.tmv) if you want. That way every new created file has the same zoom size.
