Impossible to launch after update
Loïc
Post by Loïc » Wed Dec 18, 2013 11:10 am
I have purchased Office Mobile for Android from the site. An update was issued yesterday, but after I cannot launch any of the application any more. I have wiped cache and Dalvik, but no way.
Thank you for any help. I am on Android 4.2.2
Loïc
Re: Impossible to launch after update
Post by martin-k » Wed Dec 18, 2013 11:10 am
Which Android device do you use?
Loïc
Post by Loïc » Wed Dec 18, 2013 11:52 am
Xperia Ray, with a CM10.1 ROM
Post by sven-l » Wed Dec 18, 2013 12:01 pm
We are working on a solution and will inform you as soon as it is available. Thank you!
Loïc
Post by Loïc » Wed Dec 18, 2013 12:05 pm
Thank you
Post by sven-l » Wed Dec 18, 2013 12:24 pm
Could you please first uninstall ALL xMakers and then install the new versions, so that you are forced to insert the serial key again? If that works, we at least know that the problem is the update.
Thank you!
Loïc
Post by Loïc » Wed Dec 18, 2013 2:10 pm
Data cleared, uninstall, re-install, no way I still have force close when launching any of the 3 programs
Post by sven-l » Wed Dec 18, 2013 2:36 pm
I will send you a new version via e-mail. Please try to install it. Hopefully it will solve the problem.
JohnbCallander
Post by JohnbCallander » Fri Dec 20, 2013 11:52 am
Hi - have you broken the link from the update page when you check via tools update?
I have Tablet and Samsung phone and I cannot get either to download anything.
John
Post by sven-l » Fri Dec 20, 2013 12:32 pm
The update should work properly. If you have problems you can use the download links from the registration e-mail (the .apk files). Just download and install them and you should have rev. 685 installed.
Post by martin-k » Fri Dec 20, 2013 12:53 pm
JohnbCallander wrote:Hi - have you broken the link from the update page when you check via tools update?
John
The download links from inside the software work only if you are updating from revision 684. Older revisions displayed the links, but you could not click them. That's why the update mailing also contained direct links.
