Hi. I am trying to concat two different values in a table cell:
I have something like: #B1*#C1. It is working fine resulting a number.
But I also want to add "Total: " string value.
I tried to search for concat, concatenation but no luck.
So the ideia is "Total: " & #B1*#C1 (this is not working)
another point is that when I use TEXTVALUE= "0502513" is only showed 502513. Can I fix it?
Thank you.
Concat numbers and strings in a cell
Re: Concat numbers and strings in a cell
STRING(5*5;1)+"%"
But there are another BIG problem. I am losing variables registers when I save, close and open again the file. "Unkown Variable"
And even using: BUDGET = STRING("05022513";1) I am still receiving as value 5022513
Why don't you simply write „Total: “ into the cell and then add the calculation? And in which context do you need 05022513 as part of a calculation?
Hi Jossi, thank you!
About Total: is just an example, I did it but could be insert a "$" or "%".
And the value is not a value, but a string that represent a Budget file...Like an unique id. They use zeros in the left side too.
What is curious is if I use it: BUDGET = "05022513" will work, but in other field if I only call BUDGET, the string will be 5022513.
I also tried STRING(BUDGET;1) but the same issue...
I cannot quite follow you. Could you give us a sample document (with dummy values)?
Sorry Jossi. Since you said that cant replicate it I started everything again and, my shame, I was saving in .doc file.
After I saved it to .tmpx the problem with the variables disappeared. MY fault.
The only thing that I cant fix is about numbers now. This ID number that can be 000025 for instance, even I trying to convert it to STRING("000025";1) doesnt work for me. I am receiving "25"
Cant you replicate it too?
Here I left an exemple of the number issue.
One approach that can help us is to use space in the begin of the string. That work around solve the problem.
You are right. There is a bug in TextMaker.
In the attached sample document, in the first line I define a variable named ID: ID="0025". By adding quotation marks, i have marked the value 0025 as a text string, not a number.
But if I call this variable again in another calculation, the text string is changed into a number and loses the leading zeros (cf. second line). There is no way to prevent this; using the formula STR(ID) in the third line gives the same result (as was to be expected because STR works only with a number as input, so TextMaker clearly interpretes the original 0025 as a number here).
SoftMaker should have a good look at this issue.
Inserting a blank at the beginning of the string as you describe it is one possible workaround. Another one would be to set the original text string in a text box and referring to the text box content (see section II), a third one to pack everything into a table (see section III).
- Text string to number.tmdx
- (14.66 KiB) Downloaded 2251 times
Using textBox is also a good approach. Thank you!
Probably what is happining is that TextMaker is trying to convert the string to a value using Try Catch, so "00025" can converted to a number resulting in a true acceting the Try and " 00025" is failing so going to Catch returning a string.
But anyway, I am very impressed with this tool. Is my first time using it and it dealt with my .docx without any issues... So for a basic use this Free version is very powerful.
Thanks to the developers for giving us such a great tool for FREE.
