This File Format is not supported
iat_writing
Post by iat_writing »
I have a document saved as .tmdx that I have opened and modified successfully many times. However, today, when I went to open the document, it reads only "This file format is not supported." I do not have the .bak file, as I have so many large files that creating backups for each one would take up too much space. I have accessed an earlier version of the file that I saved as a manual backup, but it is old, and since then, I have added crucial material that I need to access as soon as possible.
I have seen forum posts on similar issues stating that if I upload the file here or email forum[at]softmaker.com with the link to this post, and the issue will be investigated. Is that still the case, or is there another way to resolve the issue?
Re: This File Format is not supported
Thank you for sharing your concern. I understand that securing your important data files may require some additional storage space, but it's a worthwhile investment to protect against potential data loss. We highly recommend enabling this backup feature to safeguard your valuable files.
Yes, please send your file to forum[at]softmaker.com with the link of this post.
We will do our best to recover your file, provided it is recoverable.
iat_writing
Re: This File Format is not supported; Backup
Thank you for your reply, but recovery is no longer needed. I found that one of the manual backups I made did, in fact, have most of the information I lost from the current document. It is possible that the file/area of the drive was corrupted outside of Textmaker's fault, as a .docx version of the file was also unreadable by both MS Word and Google Docs. I have since run scan commands on my drive that removed remaining corrupted files (none of which were critical, fortunately) and circumvented the issue.
Related to what you said: as for backups, it would be more convenient if I could store the .bak files in another location from the original files. Is there currently a way to do this automatically, or do I have to manually move the .bak file each time I am done editing the document? Will the .bak files still work if they are in a separate folder from the main document?
lgsl
Post by lgsl »
When workign with sensitive information and/or time consuming, is always a good idea to keep plenty of backups (also keep a version on a usb, an external drive or whatever you fancy just in case). It is also good idea, when the file is getting way to big, to split (manually) the document.
iat_writing wrote: Wed Dec 04, 2024 8:46 pm Related to what you said: as for backups, it would be more convenient if I could store the .bak files in another location from the original files. Is there currently a way to do this automatically, or do I have to manually move the .bak file each time I am done editing the document? Will the .bak files still work if they are in a separate folder from the main document?
Please click on ribbon command File | Options | Backup | There under option “Folder for file version” you can set desired folder, but please make sure this folder is always available and with same/better speed drive.
