script
tofftoff59
script
Post by tofftoff59 »
Hello,
I am running the PlanMaker Pro 2024 (on Linux, distribution Arco Linux), I have no particular issue on the soft itself.
Does macro or scripting are implemented in planmaker on Linux version ?
If no, I would like to know if you plan to set future functionnalities as scriptiong, macro ?
If yes, what is the roadmap ?
On Linux (and also Mac), it is quite easy (far far much easier than Windows) to interact with many kind of programming language (python, C, C++, JavaScript and many others), it is a pitty to not take advantage of it to create custom macro and thus enabling to custom to some very specific use.
Best regards.
Re: script
Currently, we don't have BasicMaker available for Linux or Mac.
Return to “PlanMaker NX and 2024 for Linux”
