I have a document that includes svg files. After exporting to epub the svg files are just missing. Examining the generated epub I found that TM tries to convert the svg into png but for some reason the png file is empty.
I'm attaching a example file and the generated epub. This issue most likely also affects TM 2024.
Missing images when exporting to EPUB
- Title 1.zip
- Generated Epub (compressed as zip since the forum does not allow uploading .epub files. Uncompress to check the file)
- (2.55 KiB) Downloaded 2032 times
- Title 1.docx
- Original doc file.
- (440.07 KiB) Downloaded 1921 times
Re: Missing images when exporting to EPUB
Thanks for your post. But we are unable to reproduce this problem. Please update your SoftMaker Office 2021 with the latest updates and then check again.
I am running the latest. S1064.0513
I was able to reproduce the issue and reported it to the developers.
Thanks. For some reason SuperTech is never able to reproduce anything of what I report, but you and one of your other collages always can.
The problem has been fixed and the fix will be included in the next service pack.
Hello guys
Thank you for your response. I appreciate your efforts to help, but I've already updated SoftMaker Office 2021 to the latest version, and the problem still persists.free fire name
The problem was fixed in version 2024, but not in version 2021 because version 2021 now only has security fixes.
Meaning: All bugs in 2021 will remain, they only will be fixed in 2024. Even if the bug impides the software to work as advertised?
I already upgraded to 2024, but I do not think is particularly nice of Softmaker to do this kind of thing.
Our policy is to fix bugs for 3 years upon release. Security issues will be fixed longer.
