Hebrew with vowel not rendered correctly
azriels
Post by azriels »
The vowels in Hebrew are small dots/lines above, below and inside the letters. If you look at letter's rectangle (space occupied by a letter), you have those dots/lines aligned to the left side of the rectangle instead of the middle.
This is yours:
SoftMaker Hebrew sample.png (5.19 KiB) Viewed 2739 times
Compare it to Microsoft (done correctly):
Microsoft Hebrew sample.png (5.24 KiB) Viewed 2739 times
I also attached tiny sample file for you to see it for yourselves. I tried to also attach Microsoft file, but for some reason the "Add files" did not work for that file.
Regards.
SoftMaker Hebrew Sample.pmdx
(6.28 KiB) Downloaded 139 times
Re: Hebrew with vowel not rendered correctly
Unfortunately, at the moment we don't support vocalization in Hebrew. I added this thread to the internal task related to it.
Return to “BETA PlanMaker 2024 for Windows”
