ODT files created in LibreOffice that includes comments in styled text does not render correctly in TM 2024 (nor 2021). Please check attached files for details.
1. Screenshot showing styled text without comments and with comments rendered in TM 2024.
2. The original ODT file created in LibreOffice 7.4.
Steps to reproduce:
1. Open the attached file in TextMaker.
Alresnatively:
1- Create a new text document in LibreOffice. Type text, style text with whatever. Add comments to text, then save as odt and open in TM.
TM ignores styles when coments are present in ODT
- test.odt
- (13.07 KiB) Downloaded 3156 times
raitis.veksejs
Re: TM ignores styles when coments are present in ODT
I managed to reproduce the problem you reported and forwarded it to our development team.
Thank you for your input! As soon as new information is available on how to fix the problem, I will update you.
raitis.veksejs
The problem reported has been solved now and the fix will be delivered to customers with the next update of SoftMaker Office 2024 Beta. Customers of SoftMaker Office 2021 will receive this fix with the next service pack.
It works fine now.
