Lots of red lines.
Kurt Lang
Lots of red lines.
Post by Kurt Lang »
Grab any horizontal or vertical line between fields and drag. You'll get lots and lots of pretty red lines until you let go of the mouse.
raitis.veksejs
Re: Lots of red lines.
Post by raitis.veksejs »
Does this problem also happen in the latest revision 1110?
Kurt Lang
Post by Kurt Lang »
Yes, still seeing it on an M2 Pro mini running Ventura 13.3.1 (a) (22E772610a).
steve1999
Post by steve1999 »
I get the same thing running MacOS High Sierra.
Thanks for posting your problem with screenshot, but we are unable to reproduce this problem. Please share the sample document in which you are getting this problem with steps involved so that we can check at our end.
Kurt Lang
Post by Kurt Lang »
Thanks for checking, but there isn't a sample document to send. It does this as soon as you launch PlanMaker with a new, blank document.
This does not occur in PlanMaker 2021 on the same hardware. In the 2021 version, a single red line follows the cursor until you release the mouse. So the issue has to be due to a change in the 2024 code.
Please click on ribbon command File | Options | Manage | Select all the options and then click on Reset button.
If required, please reinstall the beta version completely and then check.
Kurt Lang
Post by Kurt Lang »
No change.
First followed the steps to reset all settings.
Next downloaded and reinstalled the latest beta release (PlanMaker NX Universal - Beta (rev S1110.0427) 64bit ARM). First tried it as is, then followed the noted reset steps again.
Still no change. Still draws lots of red lines.
Thanks for trying the steps. Please share your sminfo.txt file, which you can generate by clicking on '?' (left corner) > About > Write system information.
Kurt Lang
Post by Kurt Lang »
Here you are.
sminfo.txt
(147.41 KiB) Downloaded 2697 times
Thanks for sharing sminfo.txt file. I have forwarded the details to our developer team for further investigation of the problem.
Our developer team have fixed this issue, the solution will be included in the next update of Beta.
Kurt Lang
Post by Kurt Lang »
Fixed in the new public beta. Thanks!
Return to “BETA PlanMaker 2024 for Mac”
