Saved Sort
KevanB
Saved Sort
Post by KevanB »
The Mac version does not save the last sort selection, although to be fair neither did the previous version. However I believe the windows version does save this information within the file.
Re: Saved Sort
Thanks for your post, but we are unable to reproduce this problem. Please share a sample file in which you are getting this problem, with the steps involved to reproduce it.
KevanB
Re: Saved Sort
Post by KevanB »
Thank you for the quick response. Prior to sending you the file I thought of a possible answer. I've tended to use the .xlsx format when saving my files, however if I move to the .pmdx format the sort is saved. Problem solved.
Return to “BETA PlanMaker 2024 for Mac”
