Change the default currency
rangel
Post by rangel »
Hi,
It appears that the default currency is the Deutsche Mark, which is obviously absurd.
Can this somehow be changed to Euro?
Ideally, one should be able to disable unused (and dead) currencies.
Thanks in advance
pete
Re: Change the default currency
Post by pete »
Hi,
I would think it has to do with one of two things:
- your template is back from when Deutsche Mark was still a thing, and/or
- your system's locale setting.
I think these determine your default currency.
rangel
Post by rangel »
Thanks,
But this doesn't seem to be the case.
My template files are from 2020 and my locale is set up for Euro.
Thank you for reporting your problem. Please share your file/ template in which you are getting this problem.
In the meantime, please check if the problem occurs in other templates also.
