Copy customization to new Mac?
solo
Post by solo »
Hi,
I have made a number of customization to TextMaker.
Is there a method to copy/export customization to a new Mac?
Re: Copy customization to new Mac?
Post by Jossi »
In ~/Users/<USERNAME>/SoftMaker/ there is a folder named "Settings". Copy this folder to the same location on your new Mac to keep your customizations.
If you are using the latest revision, you can also go to the Options dialog and click on the Manage button to export and later import the settings.
solo
Post by solo »
Thanks - I try these ideas...
