Vertical Scroll Handle
razazaidi1
Post by razazaidi1 »
Really enjoying Planmaker on my iPhone 13 Pro Max
Just one thing though.
The vertical scroll bar handle, that is the one which you can drag up or down for quickly moving vertically through the sheet. This handle at times is too obtrusive and gets in the way. it will be great if the User can be given the option to keep or remove this vertical scrolling handle
Maybe you can manage this in some future update
Re: Vertical Scroll Handle
Thanks for your feedback. This vertical scrollbar is actually dynamic, and it shows only when user try to start vertical scrolling.
Return to “PlanMaker 2021 for iOS”
