Incorrect percentages
Léon
Post by Léon »
What I have noticed for some time: even with the simplest graph, wrong percentages appear in the data captions.
Please see the illustration.
A should be 62.01%.
Re: Incorrect percentages
Thanks for sharing this problem with screenshot. This problem is resolved in FreeOffice 2021, so please upgrade your FreeOffice by complete reinstallation.
Léon
Post by Léon »
Dear SuperTech,
As far as I know I am on version 2021.
Is this the latest?
Yes, that's the latest. Then why you posted in FreeOffice 2018 forum. I have moved it to correct forum.
As we are unable to reproduce this problem, please share this sample file in which you are getting this issue so that we can test it at our end.
Also, share your sminfo file, which you can generate by clicking on '?' > About > Write system information.
Léon
Post by Léon »
The bitter truth is that I had no idea that there are two different forum sections for FreeOffice.
I accessed the forum through an old bookmark. I apologise for this.
The sample file:
AB.xlsx
(8.6 KiB) Downloaded 3357 times
sminfo file:
sminfo.txt
(12.3 KiB) Downloaded 3087 times
Léon
Post by Léon »
More than 10 days ago I posted, by request, a document above here.
Will there be any response to this?
Apparently the problem was already known in the 2018 version.
What is the status of it now, please?
Please update your FreeOffice to rev 1046 and then create a new file again, as in this sample file, the graph is corrupted and not linked with the data source.
Léon
Post by Léon »
In any case, after two recent updates, I am at the latest version.
I copied the data into a new document, but did retype the figures.
I then inserted a new graph.
The percentage is still/again incorrect.
Please see the graphic.
Léon
Post by Léon »
Before you ask, I am already posting the newly created document here.
AB 2.xlsx
(8.35 KiB) Downloaded 3385 times
Thanks for updated file. I have forwarded the details to our developer team for further investigation on this problem.
Our developer team have fixed this problem and the solution will be included in the next service pack of FeeOffice.
Léon
Post by Léon »
Dear Mr. SuperTech,
This is really very good news, I think.
The problem with the percentages is, of course, a relatively minor one, but since I discovered it I have been paying attention to it.
It will no longer be necessary to do that in the near future.
Thank you very much!
Léon
Post by Léon »
Since the latest version of PlanMaker, this problem seems to have been solved indeed.
Wunderbar! O:)
