Bug: Cannot generate Bibliographic references
lmendes
Post by lmendes »
This happens at least on Linux, I am not sure about other platforms, but on Linux Ubuntu 20.04 LTS this does happen. I am unable to generate the bibliography from a database file. I have created a SQLite database for the references and inserted two references, at a later time I do References->Bibliography->Manage->Use existing database... and select file biblio.sqlite which is properly loaded. At such point a I click on References->Bibliography->Generate and the Placement group is always grayed out/disabled, I cannot select any option in the combo box and then when I click the button OK, nothing happens, no references are inserted in the text at the cursor location, or anywhere else in the document. This no matter whatever the Mask I use for the bibliographic references.
Placement group is grayed out/disables, always
Re: Bug: Cannot generate Bibliographic references
When the two radio buttons are grayed, this means you don't have a bibliography yet in your document and so it will create a new one (the checked of the grayed options).
As to why clicking OK doesn't create one, we would need to see your document. Please e-mail it to forum (at) softmaker.com and mention this thread.
lmendes
Post by lmendes »
The email was sent on Tuesday, 30 November.
Please send your original file in which you are getting the problem, your database and complete details of the problem for better understanding.
lmendes
Post by lmendes »
Please find the document and database in the files attached to this post.
biblio.zip
SQLite bibliography database
(1.55 KiB) Downloaded 1868 times
NonWorkingBibliographicExample.docx
Sample document where the bibliography is to be generated
(12.24 KiB) Downloaded 1934 times
Please read our user manual for Bibliographies as you are skipping step 3.
