Increasing Width of Graph
mart3383
Post by mart3383 »
Guys - this may have been asked before in which case I apologise.
Is there anyway of increasing the graph width in PlanMaker. It seems to be limited to 42.44cm. This limitation does not seem to apply (or so I'm reliably informed) to competitor products so I assume it's something I'm doing wrong my end in the settings perhaps.
Any input appreciated and thanks for looking.
Re: Increasing Width of Graph
Please check if it's limited to 42.44 cm or some other numbers. If it's 42.44 cm then please share your PlanMaker file in which you are getting this problem so that we can check it.
viewtopic.php?f=383&t=22284
mart3383
Post by mart3383 »
Mail sent - regards
Thanks for sharing the file. I have forwarded the details to our developer team.
mart3383
Post by mart3383 »
Thank you
mart3383
Post by mart3383 »
Reviving an old topic as there has been the odd update here and there. I assume that this is not high on the developers list and/or cannot be achieved with the current program coding.
Shame as I like the SoftMaker product range but find that as more and more desktop screens become larger and of course wider that the PlanMaker limit on graph width I find the necessity to use a competitor product.
Hopefully when/if there is a SoftMaker 2023 released this limitation will be resolved.
Thanks for your post. I have again forwarded it to our developer team...
