1032 Update will not install
rje_nc
Post by rje_nc »
Each time I try to update Softmaker to v1032 I get the following error:
Application error:
Exception code:
0x800706b5
Address
0x53bd4b59
Exception data:
What can I do to fix this? I am running Windows 10 version 20H2 on a Lenovo T420 laptop.
Re: 1032 Update will not install
You somehow managed to bork the automatic updater. Install the full version from www.softmaker.com/en/applications as this will give you the latest version and also repair the automatic updater.
rje_nc
Post by rje_nc »
That worked. Thanks for the help.
Bob
