How to convert text to columns?
xcel_refugee
Post by xcel_refugee »
In Excel, in the Data tab, select Text to Columns ...
But I've looked all over and can't find this in PlanMaker. Searched menus, the web, the manual, did not find. Probably I'm not chancing on the right search terms. But a search on "text to columns" really ought to get me somewhere.
I understand that I can do that during Import. It's after Import that I may need to do that again, differently.
pmfrench
Re: How to convert text to columns?
Post by pmfrench »
I find it under the Worksheet menu, 12th item down.
In ribbon, you can find it under Data | Edit group | Text to columns.
