Problem: embedded graphics are not displayed in doc-file
Embedded graphics are not displayed, see attached files. Full example file can be downloaded here
- yoga-sutry-01_.pdf
- (111.07 KiB) Downloaded 1505 times
- yoga-sutry-01_.doc
- (70 KiB) Downloaded 1675 times
Re: Problem: embedded graphics are not displayed in doc-file
This is because you are using emf file format which is not supported in SoftMaker Office for Linux. Please change the file format of your graphics and then your graphics will be visible in the file.
