How to avoid overwriting in a cell
MrTdeToy
Post by MrTdeToy »
Most often than not i need to add something to a text cell that already has text, but when i do that the previous text gets overwriten by the new text.
Is there a way to make it stop doing that?
example 2.png (1000 Bytes) Viewed 17057 times
example 1.png (1019 Bytes) Viewed 17057 times
ChalkyW64
Re: How to avoid overwriting in a cell
Post by ChalkyW64 »
That only happens in my version of PlanMaker if I press the INSERT key (which toggles INSERT/OVERWRITE mode) before/while editing a cell. Maybe your INSERT key defaults to OVERWRITE?
