Chart is plotting the wrong data values
ChrisWesley
Post by ChrisWesley »
Help About says I'm using "FreeOffice PlanMaker 2018 (rev F978.0905) 32 bit" (how annoying that I can't copy and paste that).
I'm trying to chart values on a 2-Y axis chart and seeing two problems:
1. The plotted values on the secondary axis are just in the wrong positions. If I hover the mouse over a point in the series, the help text tells me the series name etc. and that its value is 59.5 which agrees with the value in the driving cell, yet the graph of this line put that point midway between 70 and 80 on the secondary Y axis. All other points on this line are also wrong.
2. I can't get multiple X axis labels suppressed.
Please see the attached screenshot.
Chris
Re: Chart is plotting the wrong data values
Thanks for reporting this problem. Please share the associated file of PlanMaker in which you are getting this problem with screenshots so that we can do further investigation.
