Moving rows with Cut>Insert
dhermosillo
Post by dhermosillo »
Moving rows with Cut > Insert seems overly manual in PM2021.
In Excel, I just need to right-click on the row and select Cut, which removes the row and copies it to the clipboard.
Then I paste it in the new location with Insert Copied Cells.
In PM I have to cut the row.
Then insert a new row at the new location.
Then Paste the row.
Then delete the previous location which is a blank row.
Is there a faster / easier way to do this in PM?
Re: Moving rows with Cut>Insert
In PlanMaker also we have "Insert copied cells", you can find it in ribbon command Home | Cells group| Insert dropdown | Insert copied cells.
More to it you can set your customized short keys for this command by ribbon command File | Customize | Customize ribbon | Type "Insert copied cells" in Quick search > Click on Shortcut Keys below > Press new shortcut key in the section below that > click Add and then Close.
This way you can use your shortcut key also for "Insert copied cells".
dhermosillo
Thanks.
Is there a way to add commands to the right click menu?
Thanks again for your help.
Currently, we don't have the customization option available for the right-click menu.
dhermosillo
One thing I should mention is that the Insert command, separate from the clipboard, is useful.
In Microsoft, if there is something copied to the clipboard, the only insert command available is Insert Copied Cells, which sometimes is not desired.
So, if Softmaker ends up adding the Insert copied cells to the right-click menu commands, please also keep the discreet insert.
