LONG TEXT fields in Sqlite database maximum size
colonel_panic
Post by colonel_panic »
Hello
I am evaluating whether or not to upgrade from Textmaker 2018.
I appreciate the new database module.
The manual refers to LONGTEXT fields as being several lines. Could you expand on this? What is the longest field I can get in there?
I'd appreciate your input.
Many thanks.
Re: LONG TEXT fields in Sqlite database maximum size
You can use up to 100,000,000 characters per record (the sum of all field lengths).
