Can I delete SoftMaker 2018?
- swarfendor437
I recently purchased the Upgrade from 2018 to 2021 - can I safely delete everything 2018 without affecting the 2021 install? Thanks.
Re: Can I delete SoftMaker 2018?
I was told yes, you can even run 2018 and 2021 at the same time.
- swarfendor437
Yes, you can completely uninstall SoftMaker Office 2018 which will not affect your SoftMaker Office 2021.
