If you try to write (anynumber)(the A uppercase)(shift+something) it will put the A in superindex and is very annoying, for example Im writting the Ohm law with units in Amper
R=10V/1A=10 Ohm
But when im writting the 1A= the software put the A in supperindex
R=10V/1°=10 Ohm (where the ° is A)
This doesnt happen with any other letter i think
I tested 1B= 1C= 1D= and no problem, the problem is 1A=
Bug auto superindex while writting 1A=
Re: Bug auto superindex while writting 1A=
Select the text and right mouse click on it. Select "Paragraph" from the context men. In the register "Spacing" make sure that "Superscript" is not active.
- Contact:
Turn off automatic superscripting of ordinals in File | Options.
