I have discovered a problem opening fixed field width text files. The files look fine in Notepad and I have checked them with a hex editor.
In certain cases it takes a digit off the front of a column and adds it into the previous column but with space(s) between it and the previous column.
I have attached an example. The rows affected are 254 Col1 Ref A375 and 280 Col1 Ref G203. This occurs in both 2016 and 2018 versions
Thank you
Stuart
Import text File
Import text File
- file.txt
- Plain Text File
- (27.53 KiB) Downloaded 4320 times
Re: Import text File
I opened your file with MS Excel 2016 and PlanMaker 2018 and the file looks identically. Could you give a sample which cell exactly is incorrectly shown?
Ok, we can now reproduce that issue here and will report it to the developers.
Our developers are working on a solution for this problem. As a workaround:
- Edit the file with a text editor
- In the first line replace the blanks with an underscore, leave only one blank between the columns. Put the underscores after the label for left-aligned columns, before the label for right aligned columns. The first line should then look like this:
"CCode SalesArea_ Items Value Average Items Value ___Average"
Then import the file as fixed width and all looks good.
