Hello!
I am using TEXTMAKER 2018 on both my MAC, and the WINDOWS version of my laptop.
A happy customer on both.
But an annoying problem on the MAC version: to save a document as templates" (modèles) does not exist. I would like my templates to be saved as in the Windows version and easily used!
Will this come in a near update?
Thank you and keep the good work!
Pierre
Templates (Modèles)
Re: Templates (Modèles)
Hello Pierre,
Fichier > Enregistrer sous..., Type de fichier: "Modèle (*.tmvx)" works fine for me. What's exactly the problem?
