This file format is not supported
Meester
Postby Meester » Wed Dec 21, 2016 12:27 pm
I have created a document in Planmaker and is working on it for a couple of day.
I have received a couple of notifications that I should update my software and did so this morning.
I am not able to access the file and when try to open the file, gets the error message: This file format is not supported
I have done alot of work in this file. How would I go about in accessing the file?
Very urgent
Re: This file format is not supported
Postby martin-k » Wed Dec 21, 2016 12:32 pm
I never heard of such a case before. Please e-mail the file to forum (at) softmaker.de
Meester
Postby Meester » Wed Dec 21, 2016 12:44 pm
Dear Martin
I have just mailed you the file.
Thank you.
Postby martin-k » Wed Dec 21, 2016 12:49 pm
I have answered you there. The file is simply cut off after a certain point. Not sure how this can happen, either a crash during saving or some disk corruption. Please check My Documents\SoftMaker\Backup for older versions of this file (provided you have not turned off PlanMaker's advanced backups).
Who is online
