How to move folders?
Post bug reports and suggestions for PlanMaker 2008 for Windows.
laffin_boy
Postby laffin_boy » Fri Feb 05, 2010 9:29 am
Hi,
I'm using SM Office 2008 on XP SP2. I see under options how to move the Templates folder to another location but i'd like to move the *all* of the folders that SM office installs to "C:\Documents and Settings\Admin\My Documents\SoftMaker" to a more convenient location. But I can't figure out where SM stores the path to these folders. There isn't anything under HLCU\Software of HKLM\Software in the registry and the ini files in the Setting folder don't have the path either.
Any hints?
laffin_boy
Re: How to move folders?
Postby martin-k » Fri Feb 05, 2010 9:39 am
Tools/Options/Files in each application.
laffin_boy
Postby laffin_boy » Fri Feb 05, 2010 9:39 pm
Hi Martin, Thanks for replying.
martin-k wrote:Tools/Options/Files in each application.
Unfortunately that didn't do it.
I interpreted your answer to mean that if I moved the location of the of the Templates folder the rest of the folder structure would also be moved. But that's not the case.
I copied everything that was under "C:\Documents and Settings\Admin\My Documents\SoftMaker" to "F:\Office\SM_Office\inst\mydoc" and then changed the path to the Templates folder in options to "F:\Office\SM_Office\inst\mydoc\Templates". Then I moved the entire SoftMaker folder structure out of "C:\Documents and Settings\Admin\My Documents" to another location. Then I restarted Planmaker and it couldn't find it's pmwconfig.ini at the former location so it wrote a new file and folder structure under ""C:\Documents and Settings\Admin\My Documents" again.
So how can I make PM and TM look for everything that used to be at "C:\Documents and Settings\Admin\My Documents" under "F:\Office\SM_Office\inst\mydoc" ?
laffin_boy
Postby sven-l » Mon Feb 08, 2010 10:01 am
Hello,
Tools/Options/Files/Template folder is only that path for the templates, not for the whole SoftMaker folder.
If you create a new, empty file "portable.txt" (without ") in the program folder of SoftMaker Office (where you can find the textmaker.exe) it will create the SoftMaker folder inside the program folder and use this new folder because SoftMaker Office now "thinks" it would be a portable version.
laffin_boy
Postby laffin_boy » Tue Feb 09, 2010 4:25 am
Thanks, Sven, that's exactly what I was looking for!
laffin_boy
Return to “PlanMaker 2008 for Windows”
Who is online
