possible BUG report: MATCH function error
Post bug reports and suggestions for PlanMaker 2008 for Windows.
Parameter
Postby Parameter » Thu Jan 28, 2010 12:48 pm
Hello,
I have discovered a possible MATCH function error where it wont return the correct position in an array. Please see the attached xls file and screenshot - it contains the error. My PlanMaker version is 2008 rev.505. I have tested the xls in OpenOffice and there it works as expected. I would appreciate your thoughts about this issue.
MATCH Issue.xls
(12.5 KiB) Downloaded 150 times
Re: possible BUG report: MATCH function error
Postby sven-l » Tue Feb 02, 2010 5:16 pm
Thank you for the example file. I referred this problem to our developers to further investigations and will inform you here as soon as I have more information.
Postby sven-l » Fri Feb 05, 2010 11:20 am
The problem has been fixed now and should no longer occur in the next Service Pack for SoftMaker Office 2010 (there will be no more new service packs for Office 2008).
The behavior for PlanMaker was not clearly defined for that case. Now PlanMaker behaves as Excel or OpenOffice Calc.
Parameter
Postby Parameter » Fri Feb 05, 2010 9:31 pm
Thank you Sven for your answer. I am glad that you have resolved the issue.
Return to “PlanMaker 2008 for Windows”
Who is online
