Planmaker saving excell format with no-existant macros?
Post bug reports and suggestions for PlanMaker 2008 for Windows.
jumping
Post by jumping » Sat Dec 19, 2009 4:09 pm
I have tried working with some excel spreadsheets in Planmaker. They are very basic and I just enter a few numbers and then resave. They do not have any macros in them and I don't create any. When I try to open them in office 2003 it launches the 'this spreadsheet contains macros' warning. When I check the 'edit macros' there aren't any listed but obviously excel is thinking there are some there when it opens the file from the way planmaker has saved it.
I have looked through the options but can't see anything that would affect this. Is there any way I can stop planmaker doing this? The file size also increases too much. They start off about 28kb. If I make the edits in excel the saved file is virtually the same size but when saved in planmaker it grows to 45kb.
thanks
Re: Planmaker saving excell format with no-existant macros?
Post by sven-l » Mon Dec 21, 2009 9:58 am
Hello,
did you saved the files in doc or in pmd file format? Can you please send us such a file?
Return to “PlanMaker 2008 for Windows”
