CSV ???
Post bug reports and suggestions for PlanMaker 2008 for Windows.
Arno Verhoeven
CSV ???
Post by Arno Verhoeven » Tue Jan 29, 2008 10:47 am
Is there a way to save a spreadsheet to CSV? I can't seem to find it.
Re: CSV ???
Post by Jossi » Tue Jan 29, 2008 12:09 pm
Save the spreadsheet as text file. You are offered export options, where you can define separators and text markers.
Arno Verhoeven
Re: CSV ???
Post by Arno Verhoeven » Tue Jan 29, 2008 12:12 pm
Thanks!!
Best regards,
Arno Verhoeven
ezee2
Re: CSV ???
Post by ezee2 » Sun Feb 08, 2009 4:30 am
Arno
Have you actually been able to save your files as CSV type or are they saved as text type in the CSV style.
I have tried the above suggestion and my files don't get saved as CSV type.
Ezze2
french
Re: CSV ???
Post by french » Sun Feb 08, 2009 9:29 pm
The file generated is a CSV file with a .txt filename extension.
If you want to subsequently use it with software that expects a .csv filename extension, simply change the .txt to .csv and you should be in business.
Return to “PlanMaker 2008 for Windows”
