Incompatibility between word and textmaker
Post bug reports and suggestions for TextMaker 2008 for Windows.
girivs
Post by girivs » Mon Apr 26, 2010 7:50 pm
Consider the following two screenshots taken.
1. The word screenshot shows the table header with white text.
2. The textmaker screenshot does not show the white text in the table header.
Any version of MS Word (2000, 2003 or 2010) shows the text properly. Textmaker does not.
Files attached
1. test_doc_word.jpg [screenshot of document using MS Word]
2. test_doc_textmaker.jpg [screenshot of document using TextMaker 2008]
3. test_doc.doc [word document in question]
test_doc.doc
Word document that behaves differently in both Word and Textmaker
(100.5 KiB) Downloaded 305 times
Same document opened in textmaker - screenshot
Word document screenshot
Re: Incompatibility between word and textmaker
Post by sven-l » Tue Apr 27, 2010 8:34 am
Thank you for the bug report which I can reproduce here even with TextMaker 2010. I informed the developers.
Post by sven-l » Tue Apr 27, 2010 9:02 am
It seems that TextMaker does not support 'Automatic' color, which is necessary to show your file properly. I opened an feature request.
girivs
Post by girivs » Tue Apr 27, 2010 6:07 pm
Here is another file where there are major formatting problems in textmaker. Somethings I observed.
1. The top right corner text is actually a header in MS Word. In textmaker, it looks part of the body.
2. Formatting problems with the tables. Tables with blue color background don't align properly
3. MS Word fits more content in Pg. 2 than in TextMaker.
ABCD_Resume.doc
(124.5 KiB) Downloaded 310 times
Post by sven-l » Wed Apr 28, 2010 8:12 am
Thank you for the hint. I've informed the developers.
girivs
Post by girivs » Fri Jun 18, 2010 9:11 pm
Any updates?
Post by sven-l » Mon Jun 21, 2010 8:09 am
Not yet. I've raised the priority a bit.
girivs
Post by girivs » Wed Dec 15, 2010 4:11 pm
Still no updates?
Post by sven-l » Thu Dec 16, 2010 10:07 am
girivs wrote:Still no updates?
According to the issues you reported:
#1: Header text and body text are painted in the same color. Word does it different but we decided to keep TextMakers way as it looks better than in MS Word
#2: This has been fixed and and looks better with the current Service Pack (Revision 591)
#3: That's a Word option to hide pgfs after tables which we cannot change due to TextMakers Word compatibility.
Return to “TextMaker 2008 for Windows”
